head gasket
hi guys, the head gaskets let go on my zed :cry: been looking at the gasket kit on conceptzperformance but was wondering if its any good? and is there a differance between left and right hand drive gaskets? the kit works out at around £251 if that helps, thanks
no, left and right headgasket are identical
oh, and there's also no difference between LHD and RHD gaskets :D
Just seen the kit, its a complete engine gasket set including a metal HG set, comes with all the other little gaskets here and there also.
Is that would your after the cometic type or do you just want the normal gaskets? And do you realy need all the other bits? You might wanna just purchase the head gaskets on thier own?
Edited by j1mmytt
I'm thinkin I may as well replace all of them as I go but would like a stronger gasket on the head. May also do some flow work on the head as well
