advice plzzzzzzzzzzzzzzzz
Ive just fitted a new thermostate and water pump and give my car the 60k service it should off had 20k ago...... (this is how i picked her up) has been driving fine since could really tell the difference. was out in her today and after bout 40 mins off drivining my fan has come on and seams to run with the acceleration off the car is this normal? does the car have a viscus fan? I have noticed a silght loss off power through the gears as well since this has been goin on would anyone have any ideas on this prob as i am :headvswal with this one.... any feed back would be gratefuly appreciated..
yes, it has a viscus fan. not sure about the other problem though
yea sounds like the viscous clutch is stuck...might not be connected but i took the fan off my nissan cabstar a while back which worked perfect and put it on the bench on its back..re-fitted and it never ever freed of again and is constantly locked,i reckon when i laid it on the bench facing upwards the fluid somehow must of been disturbed in the hub and hey presto:headvswal..maybe you have the same problem i dont know:confused:
did the fan not come on when you stared the car, it should be constantly on if its the standard viscus one?
dead on is this prob easlly sorted or would i be best replacing the viscous clutch? anyhing is worth a try at this point lol
the fan has been on since i had the work carried out the car was running sweet as a nut for bout a week to and from work have been out on a long trip this weekend and was great goin up and driving bout.. parked up and done some stuff was on way home and noticed this prob then strange one
ive found once they lock its party over mate
znut thanks for this were would be the best place to pick one off these up from and u have any idea on costs?
Are you sure you cant hear the electric fan running due to a bad conection on the temp switch.The temp switch is the one with the yellow plug on it on the water elbow at the front of the engine.If its unplugged or the connection is dirty the electric fan will stay on and as this is one of the sensors the ecu monitors (code 13) it can cause it to go into safety boost mode which would give you a reduction in power.
