Hi
Where can I get some material heat shield protection for my gearbox wiring?
The cable with the heat shield on has perished and the wires are exposed.
Thanks, but is there anywhere in the uk? I only need a small section covering would some aluminium foil heat resistant tape be up to the job?
i managed to find some heat shield matting off ebay that i used for under the bonnet, not sure weather you can still get it. then with the off cuts i wrapped my loom up with it where needed, then cable tied it all neatly
