Removing ball joints
Hey,
What's the best way without using a press to get the bloody HICAS ball joints out?
Cheers,
Ste
  • Replies 48
  • Views 2.2k
do you have the hub off???
nope lol, i was trying to do it in situ.
I've got all the hicas gear off, wondering how to get them out?
Is it less hassle to get the hub off and get them pressed out by a shop?
Wow300 done my lower ball joint and was able to do it with a clamp I think. No need for a press. If its he same thing we are talking about,lol
i used this way, take a grinder to the outer of the balljoint and grind the flange off till it is level with the actuall hub, i got lots of heat on it and a solid metal bar and knocked them out towards the shocker (it just manages to drop out)
then simply put the new ones in and bolt back up
http://www.300zx.co.uk/forums/showthread.php?t=92607
took me about an hour a side
exactly what i was looking for cheers Stella! :D
This is a mare lol!
you put the heat on the hub i take it?
yup, on the part where the balljoint is, i heat it up till all the crap melts out of the balljoint and a quick whack and out they come
i'm havin no such luck lol, third time just about to have a go, its move about 1mm every time :rant:
Looks like its gona be a while.
is there anything that has a hotter flame than propane/butane?
you will never get it hot enough with one of those wickes diy jobbies, i used my works gas bottle that we use for fittings and burning off paint
*****cks, i've not got anything stronger. any ideas?
where can i buy one of them from?
try a balljoint splitter. put pressure on the balljoint with splitter and then get two hammers and hit both sides of the balljoint at the same time,that always works.
why is that then mate, I must admit I have never used one on my zed but have used them all the time on other motor's with great success.
check the link in my early post, its easier to do it the way i posted about, the flange on the front of the balljoint is old and thin, it just rips the flange off and the balljoint stays put lol
Nuts!
They don't open till monday now.
no chance of getting a spliter under there like stella says!! :(
whats the best thing to ask for? oxyacetalene lol, gas axe the bugger?
Cheers, for the help.
Nuts!
just a hand held blow torch and gas bottle will do, you could use oxy but it will prob need training certificates before they hire it out to you
cool, i'm half way lol, only took 4 hours! :rofl:
wish you were closer mate, me and my dad would have done them for £40, i wuldnt want anything, but my 16 stone hammer weilding dad needs the money and is very handy in the old lashing with hammers dept lol
if only lol, well the poxy can of aersol has managed to persuade one 3/4 out.
My old mans the same lol, he's miles away as well!
it'd been quicker to get the hub off after all :o
not really, ive seen workshop presses unable to move them, once you have mastered one side, the other will be a piece of piss
you need a bottle of MAPP gas...butane and methylacetylene-propadiene, so burns a lot hotter. Ive got one in my plumbers bag..its a tall yellow bottle but the atuall torch head iirc is about £45
here this is the type..cheaper than i thought http://cgi.ebay.co.uk/Excel-Self-Igniting-Torch-%26-Rothenberger-Mapp-Gas_W0QQitemZ380112729954QQcmdZViewItem
Edited by znut
