big thanx to sussex stu
i put a thread up saying if anybody would lend me a boost leak tester
sussex stu emailed me and said that he would send me one he had made out to me
so a day or so later i get a little parcel in the post open it up and its a tester removed my nose panel and air filter and afm popped it in ran some air tho it fixed 2 small leaks and now the car runs better and i have less white smoke now even with 1 cylinder down :( :( :(
so in summary thankyou very very much stu :) :) :) :) :) :hyper:
nice one, top man is stu
ho much air do you put through the leak detector, how exactly do you use it, will have to get my hands on one
Not a problem mate, glad to be of help.
Stella if you want one pm your add and i will make one up for you.
Stu
im not sure now much i put through as i just started my compresser you let it get around 100 psi in the tank and turned it off and put my tyre atachment on
removed the nose panle and air filter and also the afm maf what every you want to call it
put the tester in and clamped it in
put some air through and listened for any air that was excaping and fixed where i needed to :):)
hope that makes sence im not very good at explaining things :rofl:
by the way i didnt put 100 psi through it i just wated plenty of air incase i needed it
