coil pack connectors
hi
does anyone know how to remove the connector from the coilpack when they have become so hard and brittle that the little "push here" bit just snaps off ?
Maz
I had the same problem recently when changing spark plugs,the top bit broke off, i used a small screwdriver to push into the slot and push back the clip.
That worked ?? I tried a small screwdriver pushed into the slots, also tried a thin nail into both slots and still wouldn´t budge...but if it worked for you then I shall give it another go. Cheers BlueNik
Everyone of mine has snapped and are in a bad way but the shape of the wiring still holds them in place and car runs fine.
Pete
apparently some of them just slide off and some have a small "push here" bit to remove them mate
if your thinking of changing the connectors the lambda sockets from various nissans are the same fitting just make sure you correctly wire the plugs or youll burn out your coils,,,its a cheap repair that way as i bought all 6 for a fiver from my local scrapyard..oh and do solder the connectors as mine had been changed before i purchased my z and was connected with crimps(doh):eek:
I was contemplating buying new connectors mate, good tip there with the Lambda sockets, definately worth looking into. Defo solder them...not too keen on crimping wires together anyway, looks untidy.
cheers
yep, that´s them "snap here" grrrrrrrrrr
Cheers for that Dave, looks very interesting :) did they ever get back to you and quote the international shipping rate ?
Yes they did, but considering it was $62.85 shipped to the UK, and that was 5 years ago, it could be a bit more expensive now.
He's a nice friendly bloke, as I recall, and very helpful
Dave
sounds good...page bookmarked .
appreciate it :)
Maz
im pretty sure non have the push in clip mate.
all of them slide off
lol yours have probably all broke too...some of mine still have the push in tab & some dont....
  • 2 months later...
Direct link if you're not a member on the US site ... http://www.boostpro.net/prodz32coil.html
Dave
received the connectors from Boost Pro and changed them today. Perfect and highly recommendable, way better than splicing cables and sooooo easy to do.
Cheers Dave :dance:
cupl mine have snapped,
just pull & wiggle from left to right,
they come off quite easy,
Cheers Dave :dance:
Glad the link was of use to you, and that you are happy with the end result :duffer:
