caribzx project.
caribzx decided he wants to make some changes so made a start.:smash:
dan.:D
  • Replies 134
  • Views 5.9k
can a rear foglight be wired in to the front foglight via relay so they both come on at same time? is that ok for mot?
dan.:D
dan.:D
i'm sure it has to be seperate dan? just wire it back to a switch anywhere around the dash or center consol..! there will be plenty of feeds u can take it off? cigar lighter would be an easy one! i need to do mine too . think i will put them in the rear center panel & have 2x reversing lights & 2x fog lights..is that what johns doing? or just putting a seperate one on?
dan.:D
Dan, I have a relay that I bought from Zcentre that you wire into the standard loom to make the inner brake lights light up when you push the rear fog button. Hope that makes sense, will post to you for a :duffer: if you want?
As I found out my car already had a gizmo in place to active the same inner brakes lights :slap: so Zcentre is going spare.
H
H
cheers :duffer: send me a pm with what you need.
dan.:D
number plate easy enough, dont know how it managed with no fog light before! forgot johns is a 93/94 so he got the works when it came to emmisions!:(
dan.:)
Used to have a similar problem with mine. I'm probably teaching you to such eggs but give her a damn good thrashing prior to the MOT and then pull that little pipe off. Mine was a 94 and it was quite amazing how much this brought the emissions down. Best of luck.
thanks shelton thats the excuse john needs!lol going to try that with couple other things, john did say she flys now!:dance:
dan.:D
You just need a switch that can illuminate to show that its on, and ref to wiring in the previous post above, wiring will work, you dont need a relay though, it will work without, mine does lol
Good luck John and Dan! Will be thinking of you both and of course Johns Zed!
SHE PASSED!!:hyper::nana2::dance:
a bit of drama with a powersteering fluid leak but we got there in the end! keep your eye out for john he is on a mission now!:rofl:
dan.:)
thanks to everyone for their help and advise.:duffer: i did hear john mention he likes the idea of a powdercoated plenum and other bits!!!!!!!!!! :eek: :rofl:
dan.:cool:
dan.:)
Go on then, tell us how you got the emissions to drop?
she was looking dodgy but with the pipe on the balance bar pulled she sailed through.
dan.:)
think this baby is ready and from what john says its got enough power!!;) new pics soon.:cool:
dan.:D
dan.:)
Yep. Same as mine. Think it is something to do with the PC Valves but I couldn't be bothered to change them.
  • 3 weeks later...
well been down today to look over the powersteering leak and talked john into getting rid of the hicas so its coming out, was full up with roast beef so will start it again!lol:lol:
dan.:tongue_smilie:
ive got a lock-out bar up for sale mate if intrested in the other thread
Craig
