I have purchased a cat-back delete kit including the new elbows.
In the process of removing the existing cats section I have sheared two bolts from the left three point hook up to the stock elbow. This even after much soaking/heat etc.
So my question is - based on my experience to date and the above - I am pretty sure the turbo elbow fittings (two studs and two nuts) will be [hell of] a LOT harder!!! :hurl:
I need to know that if I shear a stud/bolt on the actual elbows - will I be able to recover/drill out without removing the engine etc etc.
Hi
Your guidance as ever is appreciated. ;)
AndyGP
