Car Pulling to the Right
as the title states really, only started doing it about 2 weeks ago, i havent really driven it all winter so cant really put my finger on what has gone wrong/changed. basically if you let go of the steering wheel it rights itself to centre but seems to want to go slightly too far and the car pulls to the right, there also seem to be much more resistance in the wheel when steering to the left, any ideas??
cheers
Power sterring fluid low? Could be air in the system somewhere? As it's been idle all winter i'd top up the PS fluid and then jack the nose up and with both fronts off the floor and the car running (to run PS Pump) do a couple of rotations to the left and to the right and then lower and check the PS fluid again. Other than the obvious tyre pressures etc with it being sat doing nothing all winter and my limited knowledge i'd do the above first..
May seem a stupid response but have you checked your tyre pressure? :slap:
not yet mate, gonna do it this morning, hope its something as simple as the pressures! cheers
so the tyre pressures were down on the car, pumped em all up now so i guess we will see later is its fixed the problem when i drive home
