vac pipes and a problem????
hello can somebody please post some pictures of where on the engine you pick up the vac for the dumpvalves as i want to replace the pipe wrk and no matter what i putt off they still work lol
please please help!!!
the problem i have is on the left hand side of the engine just behind the throttle body but underneath there is a metle pipe that has be cut and crushed any ideas to what that is and why it would have been cut ???
The pipe that has been cut is for the carbon canister, could be that it has been removed and they couldnt be othered to removethe pipe work...
As fir the Vac lines as i showed you the other day the only place i know to connect them is where the recircs were connected... wish i could be more help bud.....
When you popping over next week?
Cheerz
Neil
Cheerz
Neil
thanx for that neil aslong as the pipes carnt hert anything thats fine with me
ive got a car in on tuesday for some work but at the minute wednesday seems to be ok for me will be early again say just after nine :)
If they are in the recirc location use the original vac line.
If they are in the engine bay just route your own vac line to any from the balance bar.
ahh ok i will have todo that the problem i have is that the passenger side one works fine but the drivers side does not work so i linked it from the passenger side do you no what 1 from the ballence bar does the drivers side ???
