Handbrake Warning Light
Is there any way of testing the handbrake warning light? I have a feeling the bulb has blown because it doesn't come on when the handbrake is applied and after checking the switch out today it seems to be working OK. I've also pulled the connector off the brake fluid reservoir which I imagined would make the light come on? but it didn't. Does this sound like a blown bulb?
Cheers.
Blown bulb and as they are at the bottom of the dash binnacle, unless you have really small hands, you will need to take the pods off etc to get the dash out.
May have been removed to stop it lighting up.
Have your rear lights been modded at all?
Thanks for the replies. Got the instrument panel out today and tested the suspect bulb across the battery and found it to not light up so that was definately the problem. Just got to locate a replacement bulb now. Might go down to halfords a bit later and see if they stock them in there.
Cheers.
Doesn't look like Halfords have any the right size. Anyone know the best place to source these bulbs?
Can't find the right bulbs at all. All the local motor factors seem to have a bulb that's slightly the wrong size. Surely someone on here must have changed this bulb before? Where can I get one from? Any of the site traders sell them?
Cheers.
