Ive noticed an oil leak on the garage floor i cant see anything from the top managed to squeeze under car coming down on gearbox bellhouseing any clues?
I believe the most likely culprit will be the rear main oil seal if oil lools like its coming from the gearbox bell housing.
I currently have a leak from this which is slowly getting worse. It is a gearbox off job to replace, even though the seal itself is very cheap. I will be changing mine at the same time as my Manwell conversion!
Mine has just been it to Zedworld and one of my problems was that i had an oil leak, they give it a good going over and saw that two of my pullys were worn causing my cam seals to leak, take the cam cover off and see if u can see any oil on the inside, the oil slowly leaked down making it impossible to see where it was comming from.
ย
Worth a shot
thanks,but if the crank oil seal had gone surely the oil would'nt be near the top of the bell houseing would it? im taking it to a freinds pit i was hoping it might be rocker cover gaskets thanks
Dont guess mate.
get the car to a garage and let a mechanic check it out there could be many areas that can cause the leak you speak off ..
no one can say on the internet.
d
