Clock
Hi Ive just brought a Z and the clock in the dash works but resets every time I start the car I`ve been told it may be due to the way the last owner wired up the stereo.It still as the jap cd player in but thats not working and the jvc single disc that they have put in is in the slot above, ive looked at the wires to that and its not a very good job.So any pointers on what to look for.
Wolveszx
I've got a working one for £15 or AndyP on here can repair yours for you ;) doubt if it's anything to do with your stereo wire as the clocks do tend to go wrong.
Common problem with the clocks. Get a 2nd hand one or it can be repaired.
Thanks for the replies the wiring diagram will be a great help in checking it all out.Vijay I will take that clock off you do you have paypal.
Wolveszx
I´d check the power feed to the clock too...make sure it´s getting power when the ignition is switched off , if it´s not it will reset itself everytime like disconnecting the battery
