Front speaker removal
Hi I want to remove the front speakers, can I get them out without taking the door card off?
The grills seem to be pretty well held in place, I just want to remove the grill and speaker to chaeck for space for a new audio project I am playing with. :hyper:
Hi Guy
I think the door card has to come off..... Zedworld changed one of mine of Saturday and they's what they said about it
Tony
Door card has to come off buddy :(
  • Put the window down first
  • Pop out the cover at the back of the window and undo the brass screw (careful not to drop it!)
  • Remove the cover and bolt for the seatbelt at the top, you shoul now be able to remove the top cover to access the two top bolts of the door card
  • Undo all the screws around the door card and remove the plastic cover strip around the seatbelt where it goes into the door card
  • Pop out the switches and disconnect the loom from each
  • Lift the fuzzy lining to the handle and undo and remove the two brass screws
  • Pop out the handle surround (pull the handle out first to make it easier)
  • You should now be able to pop the door card off with a bit of twisting and lifting
  • JOB DONE!
Do you have much space between the grill and I presume the glass when the window is down?
I can get a door card off in about 5 minutes. Once you've done it a few times it's peasy. :)
It's a piece of cake :D
I have 4 way 6x9s mounted on the door card with no issues of thewindow clearing them
same here, 6x9s fit fine but i couldnt fit the grills on
You have to mount the grills of the 6x9 and the speaker on top of the door card, i've also seen it done with mdf to mount the 6x9 up on the door rather than on the card then the grill mounted over the door card
