Hi fellow zeders.
My car started playing around yesterday with the AT check light, it flashes when i turn the ignition on and goes away when turn the engine on, also realised that theres water coming from under the glove compartment could it be the matrix?
Water under the glovebox may be the air con drain pipe if you're lucky ;)
Any ideas about the AT check light flashing?
The flashing AT check light is informing you that there is a fault code stored in the auto box ecu, follow the link below on how to do an autobox diagnostic.
http://www.zedworld.co.uk/wizzj.html#auto_box
The water is very likely the heater matrix, are the windows steaming up excessively? a sure sign of a leaking matrix.
Jeff TT
Jeff TT
Yes they are my mate will do a few checks over the weekend, really hope Autobox doesn't need replace..
Anyway i'll keep you posted cheers again.
The good news is, when most autobox`s fail they do not show a fault code because it`s usually a mechanical failure, so the fault code warning should help you pin-point any issues.
Jeff TT
Jeff TT
:dance::dance: now thats good news for a change :bow:
hope someday i can take my zed for a full check at zedworld:D
