Is the headlight tray welded in?
Hi all
At some point in its life my zed has been jacked up under the radiator crossmember so it is damaged, atthe same time the cross member that goeas across the front of the car at the top and bolts to the air pipes and radiator has also moved upwards.
This all means that my bonnet does not sit right and I have had to set the catch at its lowest point to get it to look almost ok.
Is the front crossmember that holds the headlights etc welded in or bolted in? Is it something that can be replaced or jigged out should I just live with it?
I found this pic on Ebay and it got me wondering if they cut it out or unbolted or what?
Edited by radron
I know it might sound funny but open your bonnet and stand on the member and jump on it see if it goes back lol hahah
Already tried that mate and managed to get it back a bit. I'd be really keen t try and put it right though. Maybe I need to get a couple of people standing on it together?
big hammer and a block of wood, mine was like that after i replaced the rad support bracket, it should knock back down
hope a dont have to replace the rad bracket, what a job lol, maybe that is why the car pulls to one side whe breaking
Cheers all
Stella I'll give it a go, its going to Jeff on the 28th so hopefully he'll find out why its pulling.
