leaking targa/top of driver & passenger door
Have tried to cure leak with Captain tolley's creeping Crack Cure but have found that the leak (drip) comes from where the targa rubber meets the rubber ar top of a-pillar i.e. top of the driver & passenger windows. anyone know the cure for this other than replacing the rubbers.
I tried that cure also and it didnt work so i have bought new door rubbers that run up to the targa roof and i am hoping this may cure it.
exactly the same problem on mine-also tried tollyes crack cure-same result.also looking for rubbers.sick of wet arse!!!
I got mines from paul@SWZ
4980davidb; Did you not buy new rubbers? now trying to sell them on the forum?
You will pay between 40-50/55 depending on where you get them i suppose. Just stick a items wanted thread up on here and im sure someone will be along to help.
wrong rubbers-i bought door rubbers-need the rubbers where t-top meets rubber above window.still leaking:cry:. radron bought door rubbers.ill contact paul@swz for correct ones. you dont miss much craig:D:D:D
LOL, i hope i have bought the right ones from paul then.lol. I didnt now how to describe them so just said door rubbers that come up and meet the targa roof, fingers crossed:D!
Good luck with the leak bud:D!
There are basically 3 rubbers for each side. One that runs around the door, one that runs up the A pillar and around the T roof and the last one which fits on the T roof itself and the window closes on it :)
which are the ones that cause the hassle, i get water on the passenger seat, annoying.
guess the best thign to do would be to replace all 3
How much do all 3 cost- and to save cash does anyone know which ones are usually the problem? My drip comes from where the 'A' pillar rubber meets the targa rubber- which one is likely to be worn?
are you sure its not the drain hole? the drain hole tube is behind the plastic on the a pillar, pull at the top of the plastic and have a look
The only drain holes I'm aware of are 2 on each side of car & they are visible when targas are removed. I regularly pour water down & check it runs through & exits car underneath (i.e. no blockages). Will move the plastic & see if it's blocked or has come loose.
