My heater blower has suddenly decided to stop working. As all the lights on the climate control panel still come on and you can hear actuators moving when selected and no fuses were blown I assumed it must be the fan itself.
I checked that there was voltage at the motor connection with the fan selected on and I got the corresponding correct voltages ( 4, 6, 9, 12). So assuming it was the motor I took it out and tried cleaning it using the info on here. No joy.... So I sourced a replacement fan, fitted it... still no joy.
Reading through my workshop manual I found the self diagnosis test for climate control so tried this. Upon starting the test I didn't get the '00' code which says duff Auto/Off switch. So accordingly I have sourced another one although it is slightly different appearance it had the same connections. I put it on and did the self diagnosis test again, still no '00' code at the start.
Hello there,
Any ideas please...:headvswal
