- Replies 27
- Views 1k
- Created
- Last Reply
lusitano 6 posts
YTS Weazel 3 posts
JeffTT 3 posts
Gaz 300 2 posts
here is the result..
1. Diagnostics
Autobox OK
Engine :code 34 - det sensor cicuit (sensor or wiring)
Car running in safeboost mode
Both O2 sensors dead (no response)
Hicas Pump - lines dosed and leaking (needs investigation)
Coolant sniff test - Clear
Coolant sensor (Gauge) - inoperative
Coolant sensor (Ecu) - inoperative
Coolant - Needs flushed and replaced
Thermostat - replace
Waterpump - possible replacement needed
Coolant leak fron rear of engine - possible Hose (needs investigation)
Front Bumper - Wrong type fitted (N/A)
Engine oil leak front lower - possible FMS or Sump
Engine oil leak Rear - Possible Rear crankseal or Sump
Engine oil leak Nearside upper - possible turbo feed (investigate)
Exhaust system - Still running original system and Cats
(Blocked cats maybe causing possible restriction)
Body - Underseal required
Suspension - OK
How bad is this? is it even worth keeping the car?
How much am i looking in parts?
Please give me some advice i am so so crossed for buying a car like this!
