Defi gauges
Hi Guys
Just purchased 3 defi gauges, 60mm dia. Want to fit them into A pillar pod. The pod has 60mm diameter holes in to take the gauges, but how do you hold them in??
My old 52mm Auto gauges, had brackets that hold them in.
Any help would be appreciated
Regards
Kev
Ive got defis in glove box panel ive used a thick cable tie round the back to hold in place.
I used uhu glue which holds them in very nicely and when you remove them, the glue just peels off. You can make it look neat so there's no glued on show ;) you can also move them around once you have applied the glue to the correct position and tape the outside till it dries.
btw its the transparent silicon uhu not the paper pritstick type.
Edited by j1mmytt
