Me again.
So I have two questions:
RobHowl ·
This might sound like a dum question but whats the best way to get coolant on a 300 TT?
someone told me its not straight in the radiator, that there is a cap just for coolant and the rad only takes water, is that true?
need to get that done pronto but im kinda in doubt now..
Any advice very welcome as usual :bow::bow::bow:
