January 12, 200917 yr Right! Petrol cap flap thingy? Does it use a cable when you press on lever to flip it open? If it does how do I adjust it? mine takes ages to get it open and I need to rest something heavy on lever and flip it open by hand. :)
January 12, 200917 yr I had this problem, fixed it today actually! If you oped the petrol flap, on the hinging side, on the body, there is a little piece of metal that acts as a spring to pop open the flap, pull it out, if it looks ok, then stick it back in but not too far, that should give you enough 'springiness' to pop ya flap open, worked for me! HTH matey....
January 12, 200917 yr Author I had this problem, fixed it today actually! If you oped the petrol flap, on the hinging side, on the body, there is a little piece of metal that acts as a spring to pop open the flap, pull it out, if it looks ok, then stick it back in but not too far, that should give you enough 'springiness' to pop ya flap open, worked for me! HTH matey.... ย Top man!! :) Will give that a go in the morn! Cheers bud!
