protoj · 7 hours ago 7 hr
300zx light up centre panel has stopped working.lights up green,original-not aftermarket.problem with little white electrical box[buzzing sound],i disconnected it.starter? inverter? does anybody know-and where can i get one? please help. dave in ireland. cheers.
