In memory of Mandy
130 miles to a tank!!! is this normal?
Hi please could anyone help me?
I have a 1994 N/A and since I'v had it I only get 130 miles to a tank. It starts up fine and runs ok'ish' (fills a bit lumpy)
What I'v done so far:
-Changed the water temp sensor
-Check emissions which were spot on.
-Had a live reading with everything looking fine.
-Check ECU for fault codes
The only thing i can think that it might be is the air flow meter but not too sure how to check it.
8.5mpg.....!
a hole in the tank would use less fuel....:D
seriously though....does it smell of petrol when running / starting her up?
I've got a '92 N/A and get around 400 to a tank on a decent m/way trip so somethings definitely wrong - possibly a leak somewhere.
I get 250 - 350 miles in my N/A depending on how I drive it. Something is seriously wrong with yours, I cant believe your emissions are OK. Get to a good Z mechanic it will cost you less than 2 tanks of fuel to get the problem identified.
whent to st pancras station twice and in heavy traffic this wk/end done 287.6 miles and still got a quater tank left
Mine use to use a hell of alot of petrol use to be about £10 for around 15miles ish. but ive changed the O2 sensors and all is good :)
i filled my car up when i got it from mexbourgh and drove it back so norfolk and had over half a tank left im not sure how many miles i got as my odometer dont work but i can get 60miles from £15 worth of petrol
I can get 50 maximum, on £15
