Splitfire Sparkplugs
I think the OP may be referring to the SPLITFIRE DIRECT IGNITION kit which replaces the stock coil packs.
If that is the case then, no - definitely not cheap at nearly £400 for a set of 6. The main benefit of these is at high rpms where stock coil packs experience a drop in voltage - these will maintain the correct voltage for longer resulting in more power/torque and less chance of detonation.
Dan
If on the other hand you were refering to sparkplugs then yes, stay with NGK's.
