December 26, 200817 yr Its more worth fitting 555cc no alot more £££ Power difference will depend on boost pressure and cooling. Stock injectors are on there max at about 14-15 psi any higher and you run the risk of leaning out and causing damage to engine. With 555cc you have much more flow than your stock turbos can handle. So maybe running a little more than 14 psi will be ok, anymore and your turbos will just be super heating the air and will run less efficently, so make sure your cooling is good for 15 maybe 16 psi any more than that and you will just be loosing power than gaining really.
how much power will i get by upgrading to 440cc injectors?
