need wiring diagram a.s.a.p
just bought a 91 300zx (uk spec),someone broke into it and cut wires.the car starts with the key but when ignition turned off the car still runs,i currently have it wired up to a switch to solve this.main problem is that there seems to be a constant feed from battery as it wont stay charged.car is at autosparks at mo but even he cant solve this without a wiring diagram.can anyone help please.cheers
Assuming all the cables are back in place now, does the igntion lights stay on when sitched off but dimmer then when the key is turned on? if this is the case the ecu has been damaged and is backfeeding through the ecu pcb.
Jeff TT
