what price do a pair of tt heads go for please?
just chucking around a few ideas.
such as buying a tt block and upgrading the internals with high compression na pistons skimmed heads ported and flowed heads.
which is stronger a tt block or an na block :p
NA and TT bottom ends are exactly identical, except for the following parts:
oilpump, oil squirters and pistons (and less important, the exhaust manifold stud pattern is slightly different)
so you are saying the na's crank is equally as strong as the crank on a tt lump ?
yes, TT and NA cranks, rods, girdle and engine blocks are all the same.
Also I have heard from several sources, the socalled Nismo crank that can be bought in the US, is actually just a regular crank as well..
The only (proven) uprated crank available for the VG30DE(TT) is the one that is used in the strokerkit from JUN
one thing I forgot to mention in the list of differences in bottom-ends are the (piston) wrist pins.
thank you very much for that:duffer:
