car idles like a bag of shite and is SLOOOW in general
it idles at around 1100 rpm and hesitates when you accelerate and is shite slow and a mate who drove it said it was misfiring?!?!? if i plugged a datscan or a cunzult thing in would it tell me whats wrong?
  • Replies 27
  • Views 967
Will give you some fault codes telling you what is wrong but best bet is to check your injector + coilpack connections and the units themselves! Give them a clean with engine bay cleaner might help! Datascan will tell you if your 02sensors (and loads more info)are fooked as well which can contribute :)
awsom cheers mate! just quickly im sure someone will know this, how would i check the operation of an injecter using a multymetre? and coil pak for that matter?
Mine was like that idling really shite, rough and a pain in the ass to drive... turned out to be a leaking clutch booster and incorrect timing :)
All sorted within like 10 min and now as smoooth as a babies bottom :D
clutch booster? whats that? how in 10 mins? mines an NA defo massive boost leak!!!! lol!
err pass on the techical details Im a girl - I only do shopping :D :rofl:
I drove up to Zedworld - Jeff plugged in the conZult and did his thing, adjusted the timing, idle stuff and away I went :D Might be worth giving him a call - sure he can help :)
LMFAO:rofl:
hope your laughing with me not at me! lol!! wheres zed world? and how much did this harry potter wand waving magic car fixing hocus pocus cost?
86 miles away from my front door, thats 40 quid in petrol before he's touched it! lol!
To be fair, thats not very far, i live alot further than that, but if my car needed doing it would be straight down there. Its a professional set up, with quite possibly the most experienced zed specialist mechanics. ;) :)
Ring up first and explain what is wrong, and then go from there :)
Thats not bad considering you'll be having one of the countrys experts in Z's looking at your motor....
air leak then not boost leak and its slooooow coz its na :D lol
check your tps it may need adjusting.
Edited by j1mmytt
AFM perhaps? Can be attributed to poor running and poor performance?
throttle position sensor? how is it adjustable? its slow cos its na however it only cost 1400 quid in my eyes there aint many 210bh cars you can get for that lol!! (222bh if you beleive wiki)
£1400 but how much to get it right lol
You just need to give it a full check over on all the electric/sensors/connectors etc
Search is your friend. There is a huge library on this Site about everything and how to adjust/fix/mod your zed.
yea just been having a look, basicly clean all senser connecters and service it massively! its cost nout so far, well its in at the moment for a cambelt kit aux belt plugs diff,and engine oil change n thats costing 130 inc parts
oh my god! its 20 past 5 on a sunday and he cant get the crank pulley off!!! gotta use it tomorrow!! bloody numpty!! is there a problem with em or what?
always best to swap out the crank pulley with an under drive one, as these cars are 18yo the pulleys tend to be slightly tight to remove and may result in the cast snapping on the edges. be prepaired to replace what ever you take off with new parts;)
Always use the correct tools.....£25 or less from Halfords for a pulley remover makes it a 2 minute job.
Jeff TT
could leaking BOV's cause pish idle and for it to cut out? Or would adjusting the idle sort that out?
he got it off with a hammer! not pleased! still in the workshop, altho its costing nothing to do so i cant complain - i work with my mrs so i just went in her car, ppl keep takin the piss because we take separate cars to work, when we work in the same building.... i have a massive carbon foot print SOD THE PLANET
so would i, my lady's driving is awfull
