headlights ( STILL!!!!!! )
Still having grief with my headlights! basically the drivers side is very dim (both round and square light), on the passenger side, the round light is bright but the square one is dim! the bulbs are fine, fuses are fine, wanted to check the earth but not sure where it is, i found an earth wire near the drivers side healdlight under a couple of grey plugs, but that didnt seem to be for the lights? any ideas where the earth is, or anything else i can try before i end up going to a mental home!!!!:headvswal
the ground side of both lights goes back to a changeover relay in the engine compartment large fuse box
presumably this would then be grounded to the chasis somewher near / under the fuse box
[sIGPIC][/sIGPIC]
thanks mate, i thought no one would get back to me!
next time get in our faces:D;)..yea it will be an earthing problem that
edit...try running a temp earth from the offending item and watch it glow
this might sound daft, but if i run a temporary earth, where do i connect it from, is it on the cluster somewhere?? back of the bulb?
