November 22, 200817 yr Just recieved some pcv valves which i purchased off e-bay, just wanted to conform that all they consist of is two valves and two tubes?
November 22, 200817 yr should have 2 pcv valves, 2 hoses- and if ur lucky some instructions:rofl: so i think ur good:)
November 22, 200817 yr mmmmhhh one way and two way as well to top it off :rofl: and isn't it 2 valves and 5 hoses in total? :confused: iv'e heard that allot don't bother with the 5th hose as it's not the easiest to change:headvswal Edited November 22, 200817 yr by ck300z
November 22, 200817 yr Yep, Full kit is 2 valves 5 hoses. But basic kit is 2 valves 2 hoses. Those 2 hoses are the ones immedialty connected to the PCV Valves that tend to break when you remove the valves, so they are the important ones. The other 3 in the full kit are not as essential, but its good to replace them if your PCV valves were sticking as they will have a lot of oil residue in them.
November 22, 200817 yr As silver bulet said 5 hoses 2 valves cool thats what i meant (post edited)just heard allot of people dont bother with the 5th hose as its a nightmare to change and rarel'y cloggs gonna change mine sooner rarther than later or at least give em a good clean :) Edited November 22, 200817 yr by ck300z
November 22, 200817 yr Yep, Full kit is 2 valves 5 hoses. But basic kit is 2 valves 2 hoses. Those 2 hoses are the ones immedialty connected to the PCV Valves that tend to break when you remove the valves, so they are the important ones. The other 3 in the full kit are not as essential, but its good to replace them if your PCV valves were sticking as they will have a lot of oil residue in them. Thanks for the detailed explanation m8:) Edited November 22, 200817 yr by ck300z
