Maduri
Everything posted by Maduri
  1. Not today but sold her, gotta love Covid eh
  2. Went for a braw wee drive from Perth to Inverkeithing, then the 'scenic route' around Fife finally ending up in Dundee then back to Perth again ?. Going to be using her to get back and forward to work this week, really missed driving the Z!
  3. Moved the Lady to her new home in Perth, was great to get out on the road again, can hopefully get some work done on her now that shes under proper cover and not just a car cover.
  4. Would imagine it would be mate, plastic and age dont go overly well together.
  5. Thanks for the advice mate, will get the car up as high as possible to give myself some good eye balling room and match the parts up like you said. Won't be able to have a look until next weekend now as the weather hasn't really been the best for it but will post what I find here when I do. Cheers
  6. So basically the cats have started to crumble (as the standard exhausts do on these) so theres a blow in the exhaust, I have downpipes and test pipes (all new gaskets, stud, nuts etc are with them) sitting around that I bought a while ago to do the work. My questions are: 1. If I were to fit the test pipes that I have sitting around, would they fit straight onto the standard downpipes? . 2. If the test pipes don't fit (even if they do), can the downpipes be replaced without having to pull the engine? My Zed is a 1993 manual twin turbo, UK spec 2+2. Cheers in advance for any help.
  7. Aye it is pretty daft that something so small can cause such a big headache but I guess that's cars nowadays eh? Glad that you found the source of the problem though!
  8. Sorry to hear about the problems you're having with your Z mate. As it turned out the main issue with mine was the MAF that needed a damn good clean after being sat in an mot garage for months thanks to covid, the sporadic work being done to it and the constant start stop was sucking up all sorts of grime into the MAF so all I did was take it off and give it a good clean out with electrical contact spray from halfords replugged and she seems to be in good order now, couple of days back and forward to work with no issues. Could maybe try giving the MAF a clean out? Or like the other guys here said try checking if you have codes on the ecu since shes put herself into limp mode?
  9. It is mate, double checked when I was at it yesterday.
  10. Much appreciated for the help guys, turned out to be the MAF! Took it off and gave both it and the cone filter a good old clean out, now she revs like normal ? I am a bit worried about the MAF connector though because it's easily disconnected even with the spring clip in place, might be a good idea for a cheeky cable tie?
  11. I wish I did mate though I don't know anyone else in my area with a Zed to ask. Maybe it was wishful thinking to hope that Zed MAFs weren't as bad as Vauxhall ones Haha. I'll be heading down tomorrow after work to have a poke around and check the codes, would it help to try cleaning it first?
  12. Thanks for the suggestions guys, I wont be able to get back to the car until wednesday but will try unplugging the maf and see what's it runs like. I'll also use the guide you've posted there and see if there are any codes pop up too, never had the time to do it tonight. Would the maf go bad if the car had been sitting around for too long? Been in the garage getting work since the start of lockdown so around 6 months now.
  13. Back again to ask you guys for a bit more help. Got my Zed back today with a new mot but seems to have a bad stuttering issue when it reaches 2500rpm in all gears, the revs also hunt a bit too on idle and this seems to happen when both cold and up to temp. Cars a manual UK TT. Any advice would be appreciated
  14. Well today I finally got the Zed back with a fresh years mot! That's the good news, the bad news is that now it doesnt seem to want to go past the 2500rpm range and stutters like hell though I'll post that in the technical help bit
  15. Thanks mate, I've relayed as much information as I could find on re-routing it at the front end (including sheet shots of forums posts and pics) so hopefully they will be able to complete the work. If they come back with more questions I'll stick them on here if that's ok? Andy
  16. Apologies for taking so long to reply. So basically the garage carrying out the work has managed to install the delete kit (after a wee fight with the ball joints but they got there). As I'm keeping the TT pump and pot though they are having issues with how to re-route the fluid hoses that removing the solenoid have left. Anyone got any more advice for them, pictures or a basic how too would be greatly appreciated! So close to getting the car mot ready. Andy
  17. Great suggestion mate, I'll be popping down to the garage with the delete kit tomorrow on my break from work, I'll show them your advice and hopefully they'll know what to do (they dont specialize in ZX's but are still a good garage to get work done at). Much appreciaed!
  18. Hi folks, Just wanting a wee bit of help, preferably with pictures. So a bit of back story, my Zed has been in the car garage basically since the start of lock down for mot work, recently they made a lot of progress on doing the work after a back log of customer cars but one of the rear hicas hose burst when they started the car up to go for the test (personally feel like I dodged a bullet with that one). I've got my hands on a Hardrace hicas delete kit which is perfect for getting shot of the rear rack, arms and ball joints but doesn't come with the fittings to re-circulate the fluid at the front end of the car (I'm keeping the TT pump and pot but want to take the Hicas solenoid out), my question is: To anyone who has also done this and kept the TT equipment, does anyone have any pictures that would help my garage out when they come to create that loop in the power steering system? Any help on this would be much appreciated, I'll be dropping the delete kit of too them tomorrow. Thanks Andy
  19. Thought I would add a garage onto this list. Glenrothes Motor Services, 38 Whitehill Road, Glenrothes, Fife, KY6 2RW. Although they don't specialise in Z's, I've taken my cars here since I started driving as they were highly recommended to me at the time. I can say without a doubt that I trust their work and infact I currently have my Zed in there just now getting work done as I type this. Like I said just a suggestion for consideration.
  20. Funnily enough it was APC that picked tyres I bought up for returning too Camskill aswell, what are the odds! Hahaha
  21. Another part collected for install. Was the major fault on the mot fail list as mine has a big crack along the middle Getting all the bits slowly but surely.
  22. Ams motorsport to a decent brace for RHD models, it's where I got mine.
  23. Not done anything to the Zed apart from start her up the other day, she's now back hiding under cover. Though I have been collecting goodies for a sunny day (Replacement sump is in the garage, treated and painted in high temp paint)
  24. The size difference in the new cars is crazy :ohmy:
  25. LadyZed got a spot of fuel earlier for one last ride to work tomorrow as her MOT is due on the 4th, know for a fact she won't pass so will be off the road for a while :crying:
