brynova
Everything posted by brynova
  1. Hi please contact me to help me sort out membership so that I can access the site. Thanks Brynova
  2. i need a replacement afn ,new or used , can anyone help? bryan
  3. Hi bird i have made it a lot better by replacing top slider pin and adjusting the stops for the electric window. it is not completely cured so i will try the soapy water treatment. thanks
  4. Hello again. I have had further thoughts If the glass is loose or has any play in it when the door is open you will also need to replace the top window slider pin. Again quite easily done when you know how. £12 for the pin and a couple of qujd for replacement door card clips which will probably break when you take the door card off. Bryan
  5. Hi I have had a similar problem. i found that the drivers door window was not sealing properly which was because the "stoppers" which prevent he windows from winding up too far needed adjusting slightly. it is a relatively easy job to do when it is explained to you. I also found that the door rubbers were making a noise when going over bumps. This was solved by rubbing them with candle wax. complete cure! bryan
  6. Hi what is the exact problem that you are experiencing with the rubbers?
  7. Hi Andrew Photo tomorrow. In the middle of putting the doors back together after replacing op window slider pins.
  8. Thank you. Very helpful. I used to get stuff from MJP several years ago but lost contact. Great to know he is still about.
  9. Thanks. I think I need new as the rubber is very hard with no flexibility and is therefore leaking.
  10. Hi I am new. I have a 1993 Z32 TT UK which I have owned since 1997. i am looking to replace various "tired" parts eg door and window seals. Firstly I need to replace both top door skin window seals. can anyone help.
