Everything posted by lerchiosi
springs/shocks question
yes, i had to purchase adjustable front and rear camber arms after a year because my tyres were wearing out to quickly on the inside , but make sure u get a respectable company to adjust the camber much to my misfortune !
Best tyres to use on 18" 8j Rims
Now that Goodyear have stopped production of the almighty Eagle F1's and their successor isnt nearly as good (according to rumors) what tyres would you guys recommend for 18" rims all 8j size ?
Is it worth upgrading to a lightened flywheel ?
Just purchased a Southbend OFE Stage 3 clutch from the US, but is it worth installing a lightened flywheel (RPS or something similar) some people say it is worth it, some say the difference is hardly noticeable.....
Ztech recommendations
Dont be fooled by his charm and "technical knowledge" Ripped me off thousands and car has been to hell and back. The Semi-Proffesional website he uses hasnt been updated since 2004 , is always high up on google searches and i believe this is the only way he gets customers. KEEP AWAY
how can i resove this? injectors not working - electrical prob
Ztech (Chris Scaife) Ripped me off a few thousand quid and ruined my car, the guy is a Conman and a liar...
Well, she's finally coming home...
My Z has been off the road for 9 months after taken it to Ztech , my advice is to stay well clear....
Detective Jeff of Zedworld PD Triumphs Again!
my advice to anyone is dont visit Z-Tech WHATSOEVER, Chris and his mechanic are a couple of crooks..
ok to drop a automatic engine into a manual 300?
Ok this may have been asked before , apart from the flywheel is it ok to replace a manual engine using old gearbox with an automatic engine ? is there anything that needs to be checked or changed? and does the automatic engine have any performance differences ? Thanks in advance for any help !
How do i tell difference between a 95-96 engine and a 99 spec engine ?
Also , the crank angle sensor has a mitsubishi logo on the older engines with different connectors on the newer CAS
OK , after speaking to Sebastien at SpecialtyZ USA ive just learnt something, He says look under the passenger side head (left), embossed into the turbo intake manifold there is a manufacturing code if an engine is a year 90 - 94 the code is : L40P if its a 95+ or newer the code is : L48P unfortunately ive got an older spec engine :mac1:
is anyone in contact with ginger boy
i take it your all talking about Chris ?
ok just took delivery of a new engine from Nipponspares, one guy tells me its a 99 spec engine the other guy tells me its a late model 95-96.. are there any differences noticeable from the outside ? cant post a pic until i register soon !
Tyre sizes need some advice !
Ok the RX-8 alloys are H8 size what is the best size tires 4 these ? same as before (225/245) ??
Hello , My current tyre sizes are 225/45/17 frnt , 245/40/17 on the rear... Just bought some 18 inch RX-8 alloys they fit with spacers, what size tyre does peeps recommend on these ? i think theyre 7.5 or 8 J width i will update later ... Any help appreciated ! Thanks
clear wing indicators
also how do i add pics (on the thread, and in my account ?!!?)
just a quick 1, anybody know of an outlet in UK that does clear wing indicator replacements excluding Z Centre (out of stock) THANKS ! :mac1:
how to keep dipped beam on?? with high
ok thanks for the help , I have read the document on how to make the dipped stay on , only problem with this is , when the dipped beam is off and u flash your headlights, the low beam will fire up briefly, ie NOT good for the HID kit also, is there a workaround for this or is it asking too much ? :)
Just installed my HID xenon kit for the dipped beam, they are a lovely blueish white colour but when i switch between dipped and high beam OMG its like being at a disco :hyper: !! High beam is a dull yellow halogen and it cant be very good for the HID's to keep switching on and off all the time? Does anyone know any way of modding the Lighting system so Dipped Beam always stays on ? even when you flash your high's ??
