dozerbully
Everything posted by dozerbully
  1. Well just got time to look at n/S Window bad connector n/s kick place ps power window amp only works one shot o/s window n/s still works with box out of car ? So that clears that one up thanks for all help cheers
  2. yep will do might just be a bad connector plug on n/s harness :drool:nice one will try that
  3. thanks for your replays replaced o/s window switch and n/s switches today still no luck :thumbdown: p/w switch on o/s is on and still no luck my be secondhand parts faulty will open little black box to see if i can see bad joints:angry: still think it is a bad earth but then again no other faults on car other than that old prop with the power steering going on and off when i go over a bump or pot hole :glare:still got to sort that one out ...will report back when if ever i sort it out may help others on day ..., if anybody thinks of anything please and to thread
  4. thanks for your replay did try secondhand little black box today but no joy, the fault is n/s window.is the little black box just for o/s one shot window lift only {auto lift to limit}
  5. thanks for your replay did try secondhand little black box today but no joy, the fault is n/s window.is the little black box just for o/s one shot window lift only {auto lift to limit}
  6. hi all hope some one came help n/s window not working ,i can power window up with power prob so motor ok,if i prop switch live ok on lift and live ok on down side of switch when pressed but no earth on switch points in any pres of switch can any one tell me were are the earth points are it got power in the wright places but no negs,just as if there a bad earth
  7. hi all hope some one came help n/s window not working ,i can power window up with power prob so motor ok,if i prop switch live ok on lift and live ok on down side of switch when pressed but no earth on switch points in any pres of switch can any one tell me were are the earth points are it got power in the wright places but no negs,just as if there a bad earth
  8. hi just got my first z car ace:tt2: well first job was heater rad leaking :tt1: well sorted now took out dash? well that's when i found a vac hose that come out of the back of the fuse box on o/s kick panel. is blanked of with a old bolt anybody know where it should go my car is a 1990 zx300 z32 non turbo jap import:helpsmilie: please ??? ps thanks to all info this club is ace:tt2:
