Dpc1183
Everything posted by Dpc1183
  1. 10w40 or 5w30 semi synthetic depends what mods your running.
  2. Mine is a 93 on an L reg UK spec
  3. Hi all, just a quick question, but where can you get a decatted zx mot'd (in north west)? Cheers
  4. Hi all I have a 93 TT auto (UK Spec) and my diff light has come on. The diff itself is rather wet and greasy (not water more oil consistency) is the diff goosed or can you just replace the seals?
  5. Mine had shaking under breaking at 30-40mph and i had to rebuild the callipers and Put renew the break fluid and that cured the problem.
  6. I am swapping all interior, it does have leather heated seats so if anyone needs any feel free to make me offer. It needs all new tyres anyway now after a few track days they are rather low on tread. When I fitted new discs and pads (3 weeks ago) I had to rebuild all calumets and bleed them through so shouldn't be any moisture. What's the best mods to do for 500hp?
  7. Ha I have done a little bit of work on mates scooby but even scooby to zx is a massive jump but I am not going to rush it so it should be ok. I am aiming for about 500hp and a manual conversion. I am not really putting a budget on it unroll I have stripped it down see what needs changing or repairing (more it costs the longer the project takes). (I have already done an engine change on the zx as I blew last one up (on the day i bought it) melted a piston and bit of the block as previous owner cranked boost up with out chipping ecu)
  8. Hi all just after a little bit of advice for my zx over winter. I am taking it off the road this week and rebuilding it over the next 6-8 months. The car will be covered with a water resistant car cover but is there anything else I should do to protect it as I don't want it rotting away or seizing up. I am also going to take pads out. As discs and pads are brand new. Reason for taking zx off road is due to a tapetty / sticking valve noise from rear passenger cylinder so I need to strip it down and have a look plus I am going to do big power and weight reduction mods ready for nurburgring in June. Any advice on prep for winter and modifications are welcome as I am new to zx's and jap cars. Only rebuilt original minis before this zx, so should be fun as it's a massive step up. Thanks all Dave
  9. Normally if auto gearbox is goosed your best doing a manual conversion (kits sometimes available in items for sale section - about £500ish) that's what I'm ping to do when my auto box dies Good luck Dave
  10. If you are willing to travel to Preston (Leyland) with it a friend of mine Ian is manager at oakwell garage and auto electricians he has rebuilt a few zx's he might be able to help. Tel: 01772 453836 ask for Ian (tell him dave c from Motosave recommended you) he may even do it as private job save you some money
  11. I had that on my zx and i needed to drain brake fluid, put new brake fluid in and rebuild a caliper as it wasn't tightening on the disc evenly. On mine it was shaking at any speed over 20 but faster ou do more aggressive the wobble was. Hope this helps.
  12. on my zx there is a diff oil light next to the engine check light, will have a look this afternoon see if i can spot a boost leak might also check plugs and see if they are ok (but they are only 1000 miles old so should be ok). Thanks for your help mate
  13. Hi all, Could do with a little help / advice as i am having a couple of problems with my Z32 TT. Firstly the diff oil light started coming on this week. i have had look at the back of the diff, where normally there are two plugs one top to fill up the oil and one at the bottom to drain, but these arent there so where are they located on the Z? Also when i start my car from cold it wants to cut out and i have to genltly press the throttle for about 15-20sec (only upto about 1000rpm) and then when i take my foot off the revs fluctuate for about another 15sec and then it has a steady idle. Has anyone had this problem and know what the fix is? Cheers Dave
  14. Ha I watched an old top gear 'rear wheel drive challenge' last night when Hammond had a 300zx, Clarkson said 300zx are porn stars cars. Ha cheers clarky. New topgear was ok but I hope it doesn't start loosing it's mojo. Rolling over the reliant was good fun to watch though.
  15. Will do cheers for help guys
  16. I have just bought a replacement engine and I am about to receive it over next couple of days, I have bought it without turbos and I believe the engine is out of a manual car. Will the turbos off an automatic fit on the engine as one of them is bigger on the auto car aren't they?
  17. Hi guys I have just bought a 300zx twin turbo. Having major problems. Doing head gasket change and found that the block is goosed due to pinking does anyone know a good local place to get a block or an engine from, or does anyone have a good condition one that they want to get rid of. Any help or advice would be greatly appreciated. Thanks guys.
  18. Hi guys im from Preston, car is off road at minute due to blown head gasket, just re-building it at the moment
  19. Cheers guys have ordered complete headset and I'm going to change water pump aswell whilst I'm taking it apart. I have autodata for the torque settings. Is there a better manual to use?
  20. Hi all, I am doing head gasket on my 300zx, I am stuggling to find head bolts. Do these need to be changed or are they not stretch bolts? If they need changing where can I get them? Also has anyone got any tips this is first 300zx head gasket changes I have done. Cheers.
  21. Cheers. Will take it off tomorrow and get turbo force to check it
  22. Hi all, having a few problems with my new 300zx twin turbo (auto) there is loads of White smoke coming out of passenger side exhaust I have taken turbo pipes off and there is no water in the pipes. It is not loosing much water or oil but turbo doesn't seem to spool up. Does this sound like a goosed turbo? Or could it still be head gasket. It ticks over fine just when you rev engine it pushes out White smoke. Plus can anyone give me the co an co2 levels / percentages at different rpm levels? Thanks for reading this any help would be greatly appreciated. Regards Dave
  23. Hi guys and girls just joined the 300zx club as i have just treated myself to a 1993 twin turbo targer top which is the good news. bad news is when driving home either the passenger side turbo has gone or the head gasket :sad: but the bit i got to drive in OMG WHAT A MACHINE!!!! i am hooked on them and i am already looking at getting another once i have fixed this one so i can use one for work and everyday car and build another up for destroying the nurburgring in september. Anyway little introduction about myself Im Dave I am 23 and live just outside Preston (Lancashire). feel free to ask me any questions or anything. (Oh i can also get low priced quality parts if you need something try motosave in leyland lancashire and say Dave C recommended the store and you can get about 25% off trade prices!! number is 01772 421086)
