coju
Everything posted by coju
  1. Hi Front of engine is stripped down, crank is lined up so it looks like i am good to go. Will try tomorrow. Thanks for everyone's input. Will keep fingers crossed that is starts colin
  2. Hi Front of engine is stripped down, crank is lined up so it looks like i am good to go. Will try tomorrow. Thanks for everyone's input. Will keep fingers crossed that is starts colin
  3. Hi Have all marks on cam lined up and marks on crank pulley lined up. Not sure whether crank pulley is on compression stroke(TDC) or exhaust stroke. May try and rig up airline and see if its holds pressure which if i`m correct should be tdc, colin
  4. Hi Have all marks on cam lined up and marks on crank pulley lined up. Not sure whether crank pulley is on compression stroke(TDC) or exhaust stroke. May try and rig up airline and see if its holds pressure which if i`m correct should be tdc, colin
  5. Hi All Having recently been unfortunate to have a broken bolt on tensioner pulley. Have stripped down and replaced bolt, how do I confirm that the crank is on TDC . Have read lots of guides http://www.300zx.co.uk/forums/showthread.php?135139-Align-timing-belt&highlight=cambelt Cambelt is back on but as i know the engine was turned over with the belt loose not sure whether crank is on TDC or not? Is there any simple way of confirming? Thanks Colin
  6. Hi Jeff Thanks for the reply. Will try and get broken bolt out at the weekend. One more question, i can align the cams back up but how can i tell whether the crank is on TDC, i can align the mark but not sure what stroke it would be on?? Have read lots of guides online including your one herehttp://www.300zx.co.uk/forums/showthread.php?135139-Align-timing-belt&highlight=cambelt but all of the ones I have seen are just replacement without the engine having moved . Thanks Colin
  7. Hi All My 300zx tt auto had an undignified ride home last week on the back of a recovery truck. Upon investigation the conzult told me no signal from CAS. Cleaned connection tried another CAS still no go. Been out there today, stripped front down and found bolt holding tensioner pulley sheared off :( Whats the chances of no damage???, should i be hopeful or is it time to say goodbye. Before i move any pulleys is there any sequence/order i should move them in order to get them back in alignment? Will try and get another tensioner and do a compression check keeping fingers crossed. Was running really well until then. Colin
  8. Try btjunkie or isohunt. Both up and working when i checked. Colin
  9. I was tempted by this.. What does everyone think its worth? Colin
  10. Hi Mick Cant pm you as your not a subscribed user. Am normally about most weekends if any use. regards Colin
  11. Hi Got a Conzult cable if your near chichester. Welcome to plug it in and see what it shows up. Regards Colin
  12. Hi Madmax Am just down the road in chichester but work in Portchester. Could bring my zed over if any help?? Should be able to feel a blocked rad?? Air lock not so easy, but should still be able to rule out. Am available during the day to offer any help, moral support etc.. Two heads are better than one ( maybe not mine lol) pm me if I can help Regards Colin:thumbup: Dont give up on the last hurdle
  13. Hi Got the conzult cable out, connected it to my "zx", no red and green led coming on with the ignition??:angry: Has anyone got a wiring diagram for the ddl connector. have looked and cant find one. :no:Would be nice to trace the wires back. Have got no warning lights coming on with ignition apart from alternator light, was hoping that was the bulb check relay, which I havent checked yet. I know its behind the fuse box in the drivers footwell. Any other suggestions what i can check?:thumbup: Thanks Colin
  14. Good idea will post a couple of pictures.
  15. Hi all Thanks for the warm welcome:thumbup1: Henry I am right near St Richards hos. Will clear garage to keep car in, dont want to get her too wet lol
  16. :helpsmilie: Hi all Bit of a long shot but seen a nice 300zx, well looks nice lol.:cool2: Few more tweeks on than mine. Anyway been talking to the owner seems a nice chap, but no paperwork to back up what he says. Before i motor some 300miles to go and do a deal, was wondering if some kind experienced z owner would vet it over for me??:thumbup1: Would happly reimburse anyone?:duffer: Sorry if i`m not meant to post but thought it cant hurt to ask Thanks in advance Colin
  17. Heres a couple of pictures
  18. Hi Been looking for a 300zx for ages, saw a couple of wrecks then thought i found a really nice one. Heart ruled head a bit and bought it.:oops::oops: Its a 91 jap import tt auto. Body is very clean and original. Had a hesitation when drove home, eventually found fault to be dirty tps connector. Drives well now i think? Nothing to compare with lol. Got couple of faults to sort out, fan for blower not working.:helpsmilie: Next confusing one, only got battery light come on with ignition, no a/t or any other warning lights.:helpsmilie: I dont think the overdrive works as nothing happens when driving, only uses 3 gears, o/d button on or off? Glad i joined this elite group.:thumbup1: Will probably have to get another one with lots of goodies already on. Regards Colin
  19. Hi Mikael Can i ask where you ordered them from, did you have to pay any duty when they arrived? Regards Colin:thumbup1:
