cburto
Everything posted by cburto
  1. I'll be there after 11 ish.....
  2. My Revs dip from idle, and i have noticed that some times the temp gauge goes down when accelerating? Harness or sensor?
  3. Try Heritage classic car insurance, I'm paying £175 for the year!
  4. How about 13:00 on Saturday 14th August somewhere on the coventry side of birmingham?
  5. I'm good from when I'm taxed in August, Sat 14th would be ideal.
  6. Try AP Racing on line, they have good discs.
  7. Hi, What is the diameter of the block that replaced the MAF? I need to make one in work..... Cheers
  8. I fitted a Z1 shifter last year. Easy to fit, fantastic to drive!
  9. Thanks, so when your discs need replacing, you would have to re-drill a set of BMW discs? Cheers
  10. Sorry I've taken so long to type these up, Thor Racing set my boost to the following; Boost Mode Lo Hi set 55 75 gain 15 10 start boost 40 120 warning 5.0 10.5 limiter 10 3 This is on a PRofec B-specII
  11. Damit! I was hoping I'd stumbled upon a cheap upgrade option! I'll keep looking.......... Thanks Jeff.
  12. Just found on Ebay someone selling brackets to alow you to fit 315mm BMW E36 M3 brake discs to the 300zx. Has anyone done this? Is it worth it? Cheers, Chris.
  13. custom cages in Daventry, cost about £750 but that also included seat mounts for driver and passenger aswell as colection and delivery from my house. Then the wife painted it in silver hammerite. not finished yet, next year car should be alot cleaner inside......
  14. Yes, it was me. Did a 14.03 with a poor start for the first run. Better start on the second run but missed third!!!! - only got a 14.24 on that one. I belive with a better driver/more practice, the car is capable of a mid 13s run.
  15. It was £115 for the hour, they did as many runs as they needed to set the boost controller and get some accurate figures.
  16. 310bph at the wheels and 345fb/lb torque at 3800RPM. Not too bad. ill let you know the Boost controller settings when i get a chance.... Chris
  17. no, nothing has come through - try again.
  18. yeah, sure Email: chrisburton@live.co.uk
  19. Shame it's on the same weekend as Brighton Speed Trials - I'm competing in the Z http://www.brightonandhovemotorclub.co.uk/entry_st09_car.php
  20. Thanks, yeah, better than I had before. Thor Racing are tuning it on the dyno this morning so be interesting to see if they need to change it. chris
  21. Have an annoying rattle that sounds like it is coming from the rear diff area. Happens below 2000RPM (usually in 2nd or 3rd when the engine is working hard) and sounds like the exhaust is hitting a heat shield and then fades away as I accelerate. I have new oil in both G-boxes, new Nismo G-Box mount, single piece drive shaft. Noise was there before I made these changes as well. Tonight I have removed the centre heat shield and starter heat shield to eliminate those and the rattle is the same. Noticed that the drive shaft can rotate about 10-15 degrees without the wheels moving. Is this movement normal? Help greatly appreciated!:D
  22. Thanks for sorting a good meet! Chris
