toger13
Everything posted by toger13
  1. ye well i have printed the list off piston heads and am going to fax it to them in the morning they said i can keep the car for 3% of the total cost which i will prob do i was just abit gob smacked at the 800 quid lol i supose some people will take the first offer so they start low Thanks Si
  2. Hi guys im after abit of advice my Z got run in to a few weeks back the insurance company have been dragging there feet they finally decided its getting written off now they rang me today and said it was only worth £800 quid which i find hard to belive as there are 2 engines on ebay for more than that lol what do you think its worth its a 1992 300zx twin turbo Manual graphite gray UK car 145`000 miles reasonable condition the usual bit of scab on the rear arches been my daily driver for about 10 years Thanks Si
  3. right i have just been out in the cold lol unplugged the time control unit plugged it back in fault cured :D will see how long it lasts Thanks Si
  4. so if you unplug the time control unit the wipers work normal apart from intermitant doesnt work at all? i checked the switch and thats all good but i ran out of timeto check everything else Si
  5. mine has started doing this did the wiper motor cure it Si
  6. that looks the part i always think the standard one looks home made lol Si
  7. lol havent got a graph yet its is still at the dyno place but it showed 300 at the wheels and while trying to smooth the delivery out to protect the box and clutch coolant started pissing out of the turbo pipes so have sent some new braded ones up which will hopefully be ok at the mo its using a 206 gti180 box with urated bearings and lsd and adaptor to fit my engine with custome made alot stronger shafts with an AP twin plate lug drive clutch soon to have an uprated dog box after mapping is sorted and paied for Si
  8. cant see why not mine also has a speedo fault but speedo doesnt work and hicas lamp comes on so this would indicate a faulty sensor? Si
  9. some one has to do it lol its 300 horse at the wheels though and about 800kg :D i have feed it from thermostat housing and it returns in to the bottom hose but as its a shitroen the standard pump probably doesnt have the flowing capacity to do the extra lines and the huge rad lol the french never over engineer any thing :rofl: im going to get a booster pump to help the whole cooling system and the proper digital controller to regulate the temp more accuratly does any one have any pics of the turbo coolant pipes on the Zed or know what size they are? 14mm hopefully? lol Thanks Si
  10. a boost pipe could have come off? i changed both turbos on mine with out taking the engine out so it is possible Si
  11. well i think it is getting hot as the coolant supply must me slow this is also why im fitting the booster pump to cool it all the time the engine is running fine and at perfect temp i really wanted the turbo timer to work just as a turbo timer the pump will have an ignition live so will work while the engine is running but i wanted it then to stay on after shut down i could do this easy with 2 timers but thought there might be a unit out there that had 2 functions that i could then relay to the pump Si
  12. hi i wonder if you can help me i want to know if there are any turbo timers out there that do the normal thing but then when they shut down the engine they then alow another timer of say 2 mins to alow my water booster pump to run? its not for my Z, i have a saxo which i have turbocharged and it seams to be fine running its only at the dyno stage hasnt been tested on the road yet but when you switch it off even if its only been idling for a few mins you can hear the coolant boiling in the turbo so i am going to fit a booster pump which will run all the time normal then stay running for a few mins after switch off im sure the turbo will cool down to a suitable level pritty quickly with coolant through it and no hot gas? there is the challange for you all. i know its french but it will be fast Thanks Si
  13. do they do the nismo one? from what i have read you cant buy the standard ones without the arm? is that correct? Thanks Si
  14. i ment states not stakes i must be hungry :D Si
  15. hi my front torsion bushes are shot there are all cracked and one is barly attached was thinking of going poly bush till i read the warnings on here where can i buy the slightly uprated nismo bushes? i have found them fron courtsy nissan in the stakes or what ever its called lol but really dont like the 130 dolla postage charge :shock: can you buy them in the uk for a similar price? or do you have any other recomendations? i know the z centre do the polys for only 30 quid but every every where else seams expensive? Thanks Si
  16. sorted it needs a tail lamp control unit thingy Si
  17. hi ive got osr tail lamp failor all the other lamps in the unit are ok it happened after towing a trailer so i assume its just a blown fuse but for the life of me cant find which one is doesnt help being on my own in the dark as im struggling to get a torch and a test light in and my head lol any one know which fuse it could be all the other side lights are working the earth to both bulbs is good but there is no live obviously Thanks Si
  18. i knwo what you mean about custom they seem to be charging everything nowadays Si
  19. thanks for the reply also! Si
  20. well i have found an american side who do the hid conversion H3 with 4300k colour for 42 quid Si
  21. am i right in thinking that the z takes h3 dipped beam bulbs it is a uk spec tt by the way Thanks Si
  22. car has failed MOT on 3 sections on the sills where jacking points are can you buy full sill outer sections? or is it just a case of cutting the rot out and replacing it with new? its also failed on 3 brake pipes that disapper under the rear sub fame. is the sub frame easy to remove? its a uk spec tt by the way Thanks Si
  23. how much you after for it mate Si
