Karel.
    Netherlands
Everything posted by Karel.
  1. A 2+2 boot blind will fit on a SWB,so i think they are the same.My blind was missing on my SWB-NA,so used the one off my TT.
  2. http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=em&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=9&design=default&total=70
  3. http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=880107 Hope this will help...
  4. http://www.z32photoguide.com/fuses.html Hope this will help...
  5. http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=916979 Succes!
  6. My oil sensor is placed in the oil drain plug.Very easy to do!
  7. http://www.twinturbo.net/ttnetfaq/FAQpages/clutchadjustment.html Succes!
  8. I do have one...All European models have a oilcooler for the M/T :):)
  9. Start her up for 10/15 minutes,so all things under the bonnet will warm up to about 1000 degrees:rolleyes:The now very thin oil will make bleeding the air out much easyer.
  10. 72.50 euro for an original one.Same price for the one with the red stitches. http://dta-motorsport.com/ Find them in interior/accessoires. Karel.
  11. Hope this will help.... http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=bf&dir=&config=&refresh=&slide=34&cycle=off&scale=0&design=default&total=46 Succes,Karel.
  12. http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=el&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=112&design=default&total=133 3 relays,3 fuses...Hope this will help you... Karel.
  13. http://www.twinturbo.net/ttnetfaq/FAQpages/clutchadjustment.html Maybe this will help you... Karel.
  14. Let the engine run for some time...The oil will get hot too,and much thinner.Will save you lots of time... Succes,Karel.
  15. Hope you are luckey...Maybe this will help you! http://www.ttzd.com/tech/60ktech.html greetzz
  16. Had the same problem 2 months ago...After some searching found a very little hole in the clutch-hose (goes to the operating-cylinder).Took me 1 hour and about 24 euro...Let somebody else press the clutch,you should be able to find the leak. Succes!
  17. Hi Dave, Had the same problem.Not too hard to fix it yourself.Parts are about 6 euro,1 hour labour. http://www.300zx.lv/catalog/?gr=J&sec=803 Succes! Karel.
  18. Paul, You can find all wiring diagrams on http://300zx-twinturbo.com/cgi-bin/manual.cgi Succes! Karel.
  19. Hope this will help you. http://300zx-twinturbo.com/cgi-bin/manual.cgi Go to electrical systems,page 40... Succes, Karel.
  20. Sorry,wrong adress! http://www.ttzd.com/tech/tech.html Karel.
  21. Try to run a auto climate control diagnostics,before you take everything apart!Worked for me... http://www.ttzd.com/tech/hicastech.html Karel.
  22. Karel. replied to a post in a topic in General Discussions - 300ZX Related
    You should find your problem if you do a Hicas diagnostic test. Look at http://www.ttzd.com/izcctech.html. Succes! Greetz from Holland.
  23. Hi Ron, #4: What you hear is a vacuum-compressor,should only work for a few seconds when ignition is turned on.Think you have a disconnected hose.There are +/- 6 of them,leading to the valves of the ventilation/heating system.Look in the area where your battery is located.... Greetz from Holland, Karel.
