Everything posted by Corvetteman
Take a look Ebay
:wink::wink:
Hesitation at speed
Hi mate presently don't have a Z SOLD ER anyway yes I did sort the problem but can't be sure how,as I got fed up and changed air reg valve IAA valve TPS AND plugs problem went!!!!!!!!although when I changed the plugs I found that one of them had a big crack in the ceramic part ,could well have been that!!!!!!!!Hope this helps:hyper: chaZ:cool:
Swop
Check out my swop deal on items for sale:)
alloy rads ebay
I got one of these rads,have used it now for 6 months.every bit as good as any of the more expensive ones.Brilliant workmanship welds are as good as any.They are basically a Koyo clone!!!:bow: chaZ:cool: Oh yea,cost me £160 delivered--then!!!
Boost leak tester
Anyone got one I can borrow/buy:cry: chaZ:o
Boost Leak Tester
Any chance of borrowing it???:bow: chaZ
Consult
HOW MANY GCSES TO NOTICE THAT YOU PEDANTIC PRESON:tongue::tongue:
Consult
Anyone near portsmouth got a CONSULT???:bow:
- Fuel pump ECU
Ptu
THIS WORKED AND IS NOW BACK IN MY CAR(AT LAST)!!!:duffer::dance::D:bow::nana2:
Hesitation at speed
Took er up to 90 today started protesting like she was "missing" eased back ---ok,welly again started protesting again, no problem up to 70-75 tickover is good.What could cause this to happen when under "LOAD" at that speed?? :mad:Any help would be great!! chaZ:confused:
Tyres
Could be mine are standard 225/50/16's:cool:----see.......... http://www.blackcircles.com/public/order?view=standard
Tyres
lovely, a mate had the dominator looks the same:) similar to this one----------------------
Tyres
Myth.........:nono: had a couple old twins in 60's & 70's sorted them out no leaks...mind you have a few japs that leaked ........sorted them out too.Mind you having said that ,wouldnt have anything other than jap now ....Japanese liability and all that:rolleyes:
Tyres
Gotta say never had a more satisfying ride than my old bonnie...can't beat the old british twin!!!!!!!!!!!!!!!:D
Tyres
Here you go:) http://www.blackcircles.com/public/order?view=standard
Tyres
Nice bike:D
Tyres
Wet AND dry??
Tyres
How good are they????????????
Tyres
Have f1s,need replacing.Toyos about £83 f1s £85 anyone any thoughts?:) Hav'nt even had a twitch with the f1s:D chaZ
Air Con
Yea MATE THE CONDNSER FAN SUPPOSED TO COME ON AS SOON AS YOU SWITCH THE AIR CON ON(ITS MAIN FUNCTUN IS FOR THE AIR CON COOLING BUT DOES COME ON AS AN AUXILLERY MAIN RAD FAN BACKUP WHEN CALLED FOR BY THE ECU. HOWEVER AS I'VE SAID I HAVE NO SUPPLY TO THIS FAN WHEN I SWITCH THE AIR CON ON:(:(:( cHAZ:)
Air Con
Has anyone installed a manual switch to control the air con(condenser)fan. If so did it effect the rest of the air con system ie info sent from the ECU to the relays etc.In case anyone asks I want to do this because I am getting no supply from the relays to the fan ALL relays and fuses are working,fan is working too,so I am guessing there is a problem with the ECU.ANY help would be appreciated:( chaZ:)
Missing
Thanks peoples:D
Missing
DOES ANYONE KNOW IF JAMES FUNGE IS STILL ON THE FORUM:confused:
AirCon
I really really need to communicate with an AIRCON wizard.Anyone anywhere anyhow!!!!!!!!!!!!!!!!!!!!!!!!!!! :confused::confused::confused: chaZ:)
