Mikey
Everything posted by Mikey
  1. Fired it up for the first time in 10 months....
  2. Mikey replied to zerocooldel's topic in Events - UK
    Yup, I'm in
  3. I'd say stick to Livingston. Most guys are from through that way so keep it central.
  4. Gotta say, Jimmers work at PowerZed is phenomenal! I've had my car to him for a variety of engine related work and the quality of his workmanship far outweighs the 8hour drive down the M6 / M5
  5. I can do that day! I leave for another station on the 16th, for a fortnight.
  6. come on then, REO...........lets do this!
  7. Congrats on the purchase David. Looks braw! Im still here. Im busy with work until the end of september but might be able to make it to an evening KFC!
  8. Mikey replied to Ossian's topic in Events - UK
    It's worth more to me in parts than by selling it as one. I started prepping it to be used in SLS but my son arrived in November so I've no time to work on it, let alone drive it!
  9. Mikey replied to Ossian's topic in Events - UK
    Mine is about to be broken for parts so very little chance of me having it on the road again. Might try to get to a meet soon though
  10. I'm about to place an order for a new oil cooler but ive hunted and hunted for the dimensions of the standard one, so i can make sure that the one im ordering if going to show some benefit. Anybody know the overall dimensions / number of passes? I would measure it myself but its currently unaccessable. Cheers
  11. No. it's the solid ones the come out the rear of the engine which join into some silicone hoses, before they go through the bulkhead.
  12. Since my heater matrix decided to throw a hissy fit, I've removed it and I'm looking to put a permanent bypass in. I've looped the two pipes on the engine together but was wondering if anyone knows what the outside diameter of the two pipes are?
  13. That would be very much appreciated buddy.
  14. Finished mounting my harness points and installed my drivers seat.
  15. Where did you attach the pins to?
  16. I'm attempting to fit a set of aerocatches to my bonnet. I've put the pins through the holes in the slam panel, where the original rubber bump stops used to be. With the nut on the pin, above the slam panel, I'm a bit apprehensive of if there's gonna be enough space for the bonnet to shut properly. I don't want to go cutting the bonnet for the body of the catch, to realise that the bonnet now sits up. Have any of you guys had any experience with fitting these? Pictures would be greatly appreciated! Cheers
  17. finished the install of new fuel pipes from the tank to engine, complete with 10micron fuel filter and MSA Fuel Sampling Kit.
  18. week before TOTB. for that reason......Im out! (In the words of Duncan Ballantyne!)
  19. These arrived today: Waiting on the harness support plates to arrive so I can finish fitting the harnesses!
  20. Made a harness bar to fit between the rear upper seatbelt mount and bought some 6 point harnesses. gotta make the support brackets for the harness eyebolts while waiting on my new fuel lines arriving.
  21. I'm out. My zed developed a bad fuel leak on saturday so it's off the road until i can get new lines fitted.
  22. Removed passenger seat and fitted it's Cobra replacement. Discovered a bad fuel leak so dropped the fuel tank out tonight and sized up for running replacement lines, filter and fuel sample point.
  23. I'm in the middle of putting my new seats. Need to find somewhere to mount the rear harness belts until I get the cage installed.
  24. I know it's a bit of a long shot but I'm looking for a set of runners off of a front seat. Doesn't matter if they're drivers or passenger side. Not Needing the seat as they are to form the base of a subframe for a cobra bucket seat. Cheers
  25. Picked up my zed from noel and a set of seats from Slick Pete and got it home on Friday. Removed my 95+ steering wheel and fitted an aftermarket one that's been in my cupboard since August. Measured up for making a set of subframes for the seats! Production to start later this week
