atshed
    Italy
Everything posted by atshed
  1. hi. had an import few years back with illuminated sills and rear quater lights. inverters were underneath rear seats. looked like they had been fitted there as standard for that spec car.
  2. hi all. just reading up on the laws for rear illuminations on vehicles before i go down the road of rear panel lighting DIY ( thanks sussex stu for pointing out the you tube vid ). Think to keep within the law i will have to go with red ? think green can only be shown on a doctors car? so am thinking perhaps of tiny red 12v led's with a diffuser either wired to brake lights or side lights. has anyone been pulled over by the flashing blues yet for the same idea ? or come to think of it any other wierd and wonderful lighting modifications ?
  3. so its simply the internal size of each housing. thanks smithy
  4. have since then done away with the prvr system - seems to have totally cured the starting problem .
  5. many thanks. danny at the above ebay is very helpfull.
  6. hi all. being as the turbo on an auto is a t25 and on a manual is t25- can anyone tell me the difference ? the compressor wheels and turbine wheels seem identical. refurb kits are also identical. anyone out there have an answer ? ?
  7. hi all. can anyone tell me where to source a recon kit for a stock turbo ( with the better rear seal option ) will be doing the work myself except the balancing- any suggestions also on where to get balanced ( south of london ). many thanks
  8. good news ! the items i have been waiting for have just been dropped off in person by the member i purchasd from. with an appology. A new friend made also. my faith in this site is restored !. many thanks to all those who showed interest and concern. im affraid i shant be naming names but suffice to say it was none that were mentioned. perhaps that may rest some worries. a big thankyou also to Jeff for a very kind offer. much appreciated !
  9. the member has just made contact ! . perhaps this will get sorted after all. will update which ever way.
  10. dont think i should say just yet. probably best to let the club deal with it. just in case by some miracle i get my money back.
  11. will do. many thanks
  12. hi all. does anyone know who to contact in the club regarding items advertised on here by another member that i payed for and never received. the guy wont even contact me to explain why. has anyone else experienced this ? ? i have been a member now for a while and so far found this club to be extremely helpfull for advice and parts. it would be a real shame if people started to abuse the trust and honesty promoted by most. any advice on this would be great.
  13. thanks jeff. will check
  14. thanks jeff. am waiting to hear back from one other at the moment. will be in touch.
  15. speed sender unit on gearbox faulty or dry solder joint to rear of speedo. nearly took out a fuel pump in a filling station when this happend to me. sometimes the speedo went the opposite way right off the clock- made the 4 wheel steer quite amusing at 40mph ! ! !
  16. take it you brake with your left leg then ?
  17. speedo ok? or does it drop to zero when fault occurs
  18. shall try a swap. many thanks .
  19. hi all.is it possible to service the brake booster ie- new diaphram ? if so any ideas where to source parts needed ( except nissan ). if not - does anyone have one without leaks? regards cris
  20. hi to all. car starting instantly when cold. also fine when hot. but if left unstarted for 15 plus minutes when hot -then the problem occurs. will not start except after 5 to 10 seconds turn over. sometimes, for no apparent reason, its ok -but mostly the problem is there. car cools right down and hey presto its back to normal. have checked : plugs cleaned ptu checked all contacts that i can get to no fuel leaks that i can find / smell temp sender not the end of the world - as oil pressure has a chance of building before ignition- but would be nice to perhaps deal with once and for all. any advice would be great. regards cris
  21. went with swintons. much cheaper than others- on an import that is.
  22. had, an auto years ago- same problem as yours. turned out to be the auto fluid cooler that was partially blocked and had starved the box. the cooler is located on side of radiator in same housing. cost me a rebuild box and larger oil cooler. ouch ! hope yours is not as serious. ( standard cooler for auto trans oil is pretty bad and well known for failing after time )
  23. thanks. will try to source one.
  24. hi all. can anyone tell me please whether or not the newer series climate control pod would work in my 1992. am tired of using the air con for a demist. thanks
  25. hi all. de cat pipes - are there any pitfalls on install, what should be done with the return pipes that run off the original cat pipes? any advice would be much appreciated. thanks.
