reply to 110 degrees
i had todo it this way because i canrt reply on the other 1 for some reason
maybe im mis-understanding, but if you see coolant leaking from the waterpump, i would do a pressure test and pinpoint the leak and fix that first
oil seapage isnt necessarily abnornal. to answer your question typical symptons of a blown head gasket may include
bubbles of air coming up into your radiator remove the cap before starting
leaking radiator
milkshake coloured oil in the filler cap
overheating very quickly
running rough
water or oil leaking from the heads or spark plugs
thats all i can think of at the minute hope it helps
No posts to show
