Aircon pod not working help
Aircon controller pod is not working in my Z.
Checked all fuses and relays in footwell and under bonet.
Changed pod over aswell.
Any suggestions working fine one day next day nothing.
Are the wipers working? if not then the aux power feed ( key position one ) is faulty. The fuse box is split in to relay switched grids and often the relay or the actual fusebox can fail due to corrossion, also the ignition switch can cause the same problems, check the back of the ignition switch as sometimes the connector can work itself out a little and become a bad connection.
Jeff TT
i had this not long ago after my car had been off the road for a year was corrosion down at the fuse box took everything out one by one and cleaned them never had a problem since
Thanks guys will let you know how I get on lots of checking to do
