Radiator hose
Where can i get performance radiator hoses as mine are starting to perish, i also have a larger uprated radiator if that makes a difference:D
Danny at DTA can supply these for both standard and after market radiators.
No need - here I am! ;)
What I would need to know is what the outside diameter is of the top radiator outlet. Is it a Koyo or Howe per chance?
I would normally recommend our hard pipe kit which replaces the rubber radiator hoses with shiny stainless steel ones (with silicone couplers at either end - available in red/blue/black/yellow). As yours is an after market radiator I would need to see if that still fits. Alternatively I can do you a full silicone hose kit but again, if the water outlets are of a different size compared to stock I'd need to look into it.
Cost wise you're looking at:
Stainless Steel top hose only: £60.00
Stainless Steel top & lower hose kit: £140.00
Silicone top hose: £35.00
Silicone top and lower hose kit: £99.00
I don't have any full silicone kits in stock and would need to get them ordered in (can take upto 4 weeks).
I would recommend you stay away from ordering any silicone parts off ebay as most of that comes from China and isn't true silicone so won't last very long. All our silicone parts are a minimum of 4-ply with 1-ply liners so very robust and won't collaps in under pressure.
Incidentally, we also do stainless steel and full silicone boost pipes to match! ;)
If you want to discuss this further you can call me on 0845 4744-382 or drop me a PM.
Regards,
Dan
