water problem
Is it down on power? If your losing water, are the footwells damp.
check heater matrix or may be a slight hole in the pipes for coolant system.
Need a bit more info mate.
head gasket problem loosing coollent but its not mixed with oil wat can it be
Get compression test carried out and water system pressure tested, either one will confirm whether you have a head gasket is leaking or just a water leak from another source.
