I drive a G reg import 300zx twin turbo with an auto box.
When I come to a temporary stop, say at the traffic lights should I shift to neutral and then use the hand brake?
I think I should because …..
I am racing around too fast, see the lights at green and go for it! But they change so I throw out the anchor and stop with 2mm to spare. Now my front brake pads and quite hot,
Digression … the front pads seem to do a lot more work than the rear and get replaced about twice as often as the rear… End of digression
So, as I said, my front brake pads and quite hot and if I keep them pressed against the disks there is a small, but finite, possibility of warping the disks. Therefore I use the hand brake, which applies only the rear brakes, allowing me to release the foot brake and not heat up the front disks!
I watch out for the lights controlling the opposite direction and when they go yellow I engage Drive, foot on brake and release the hand brake, my lights go red and yellow and I burn the two seater roadster next to me – sucker!
If you disagree then please explain why using simple clean language.
Simon
