Fuel Flap Question
Is their a way it can be adjusted to fit flush, its seems to really stick out and it doe'nt look bent to me.
It sounds as thought the actual brackets / hinges are bent. You may need to tweak them with a bit of physical.
Nothing looks bent, hinges barackets etc. I'm thinking its just and adjustment needed. Where are these two screws Spin Doctor?
Open the Fuel panel, and you will see them. :nelson:
Problem being its usually dark when She gets home !!! lol
Will give it a try thanks!
open the flap so to speak ,two phillip screws might be tight give them a tap first should be able to get enough ajustment on them.:)
they are the screws that hold the flap to the body. Undo the screws, move the flap, tighten screws.
Having one of those SLOW days today !!
know your not im betting you have not looked yet and just inquiring?
anyway Slow days what are these?
I thought the two screws only adjusted the flap relative to the aperture.
check that the rod that whole flap hinges on hasn't come out of one of the holes.... that happened to mine... easy fix !
