autobox
is there anybody in the north west that could possibly do a electric test on my gearbox and or engine to find a fault as it wont change gear properly thanks
you can do a gearbox sef diagnostic, although i don't know the preceedure....sorry. Someone else will, or do a search
i have done a self diagnose and changed my throttle sensor but it still isnt working as should do.just need a scanner or something to tell me what is wrong coz ill be damned if i know what it is lol!
The autobox cannot be scanned as such, however a ConZult or similar system can be used to view the ecu / gearbox operation, the inbuilt fault code storage is only a start point and cannot be relied on fully.
The solenoid pack in the gearbox is controlled by the ecu and these signals can be viewed along with internal box temp, internal revs, road speed etc and duty pressure percentage.
When this information is viewed whilst undertest you can determine if the ecu is working ok and if the gearbox is responding or not to the ecu commands, this will lead you to the fault and if it is inside or outside the gearbox.
Jeff TT
thanks again jeff it seems to be detioriating by the day, i dont suppose you know of anywhere that has a conzult system that is anywhere in the north west?i think i should just give up and strip it down for parts the way my luck is going!lol
